Moldflow Adviser Forum
Welcome to Autodeskā€™s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Showing results forĀ
Did you mean:Ā
Adding new materials to the database
2 REPLIES 2
1235 Views, 2 Replies
Is it possible to add new material information to the materials database for the Adviser 2012 software?
2 REPLIES 2
You can import a .udb file directly into the Moldflow database.  The .udb file contains the necessary information to perform an analysis.  This material will only exist in your database.  I hope this helps.
nordhb
if you have measured data, raw data, of material you can contact
datafittingmoldflow@autodesk.com
and get the measured data fitted and an udb-file for analysis in return.
Autodesk Moldflow Plastics Labs information at:
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
Hope this helps.
Berndt
Berndt Nordh
