Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Activation Moldflow Adviser
2 REPLIES 2
jemiey
715 Views, 2 Replies
I have installed the Autodesk MoldFlow Adviser 2012 for Student Version.
When I want to activate the product, I got a "license.lic" file and I must take it into License Manager Folder in Program Files>Autodesk>Licencse Manager. But there is no folder like that in my program files.
I have a few days to activate it. Is there any other way to activate this Moldflow Adviser?
Thank you.
2 REPLIES 2
nordhb
in reply to: jemiey
the default license folder is normally:
C:\Program Files\Autodesk Network License Manager\License
or
C:\Program Files (x86)\Autodesk Network License Manager\License
If still having issues, for student support please raise issue at:
http://students.autodesk.com , Click Support
or use: http://students.autodesk.com/?nd=problem_form
Berndt
Berndt Nordh
TravisNave
in reply to: jemiey
The term *activate* is generally reserved for stand-alone installations.  If your install is asking for product activation, then you have installed incorrectly.  Make sure in your installation options, you choose network version and point to the license manager.  You will need to set up your license manager and use the .lic provided.
Autodesk Forums:
