when I run an analysis in 3D why does it not provide cycle time, shot volume, runner volume, etc. It works in Dual-Domain.
Also, once you build a mold and runner system in Dual-Domain can you run the same thing in 3-D without having to rebuild everything?
I had a look in a 3D mesh type and Cool+Fill+Pack analysis sequence and in release:
Autodesk Simulation Moldflow Adviser 2013 Service Pack 2
For a 3D Cool+Fill+Pack, the results are available in Summary:
tab Fill : Shot volume , Cavity volume, Runner system volume
tab Pack : cycle time
It looks the same for Dual Domain, Cool+Fill+Pack
Yes, you can change mesh type of cavity in Adviser, if first imported as Dual Domain and go to 3D mesh type.
If you right click on analysis sequence, above the material data, you have "Change To True 3D".
If a closed volume, no geometry/model issues, you can change. Otherwise the choice is grayed out.
You can also go the other direction, 3D to Dual Domain, "Change To Dual-Domain".
This works also for a study with a Dual Domain mesh type for cavity, and modeled mold and cooling circuits and runners. The mold data is kept, and cavity will be 3D mesh type.
Berndt
