The UI where the factor of safety allowable stress is enetered ("Results Contours > Stress > Safety Factor > Set Allowable Stress Values") needs to be more user-friendly when working with many parts. Instead of restricting the user to change the allowable stress one part at a time, there needs to be a mechanism to change multiple parts at a time. Perhaps:
- A "Fill Down" command (Ctrl+D) like in Excel where the value is the top cell is copied to all selected cells.
- Support multiple row selection using the Shift key or Ctrl key. Whatever the user types in the "active" cell is populated to all of the selected cells.
- A command to select all of the rows that use the same material as the currently selected row.
