If you have built a FEA model with beam elements, and those elements have beam offset, and axis specific orientation when you try to add an new element where need to intersect a beam element or a need to build a connection between nodes, is very hard to do that, because the software doesn`t respect your defined beam offset and axis orientation.
It will be nice that after using the commands:
- Divide.
- Intersect.
- Extend.
The software would be detect what is the intention of the FEA model and respect the beam orientation and Beam offset.
Please see this video:
https://screencast.autodesk.com/main/details/d7a41d5e-df7d-4043-ac75-8723ceb669b5
