Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Autodesk simulation saving pressure vessel surfaces
1 REPLY 1
406 Views, 1 Reply
When a pressure vessel is created, it can not apparently be saved as a surface model so that it can be cnc milled. The export allows to dxf, iges, etc, but only the mesh curves get stored--turning those into a surface for a program like Mastercam is a problem.
Labels (2)
1 REPLY 1
Sualp.Ozel
you can do the following to save PV designer models as surface objects
1) File
2) Export
3) choose SAT at the file type
save the file
and the resulting SAT fils is the Surface model you created in PV Designer.
Best regards
Sualp Ozel, PE
Autodesk Simulation
Product Manager
Sualp.ozel@autodesk.com
