Hi, All,
Having been using ASM 2017 until last Friday. On Tuesday, I opened file & found that the Results is Blank, having nothing alt all.
After having tried several following methods with no luck, I'm turning tothe forum for help.
1. reboot the computer
2. update the graphic card driver
3. Deselect Hardware "Enable OpenGL hardware acceleration in Option
4. Rerun the analysis successfully
Thank, all.
Karl Tong
Solved by Andrew.Sartorelli. Go to Solution.
Hi Karl,
It was great to speak with you yesterday. For the sake of everyone else I figured I would post our solution. We simply ran RegAll.bat which can be found in the Simulation Mechanical installation directory.
Andrew
