The two components are to impacted to test the the strength of the landing gear and frame of the hexacopter.
I have followed the steps necessary for impact testing.
*And the contact between the impact surfaces is created. when opening the settings for the surface contact is gives error (out of memory).
Then the program shuts down reporting error.
*The simulation is carried out in drop test settings with impact plane being set below the slab model on which the drone has to be tested.
*Materials used are CRPF with Young's modulus:135 GPa, and density: 1.55e-06Kg/mm3. and for slab/base model concrete high strength.
Solved by marwan_azzam. Go to Solution.
Hi Varadude2. Welcome to the Sim Mech forum!
I see that you are getting results, so I am not clear what help you are asking for.
Hi Varadude2,
It is very difficult to know what is occurring in the simulation because your post is too general. It does not include any details that would allow someone to lookup the messages. (Have you searched the internet for any of messages that you are receiving?)
Can you provide more details? For example,
Also, it appears that you have modeled the "floor" using hundreds or thousands of elements. That has probably created thousands or millions of contact elements. That is not very efficient.
Hello varadudue2,
You say that you defined an impact plane but you also modeled the base (which is fixed) and defined contact between the model and the base.
As John mentioned, it should be one or the other.
You either use an impact plane and not model the base (ground). No need to define contact, or
No impact plane. Define contact between model and base. Use a much coarser mesh for base, possible one big element to reduce the number of contact elements.
At this point, it sounds like the program is cutting down the time step size (you are at level 2 or above). In the output table, this would be the column before the last and it's a number between 1 and 19. If you are at a high level (say 8 or above) the analysis will take a very long time.
The reason you are not seeing any change in results is because by default, the results will not be saved for intermediate steps. You will need to go to Analysis Parameters: Output and check the Output Results of All Timesteps box. This will cause the software to save and display intermediate results (when the level is 2 and above). Such change has to be done before launching the analysis.
I hope this clears things up for you.
