Hello everyone,
Can someone please explain me how to use the following function?
Draw - scale or copy
I noticed that “scale type and factor” functions (Uniform.., perpendicular …, Along line..) under “scale” tab is grey. How do I activate these functions? Is there any tutorial that gives details of how to use these functions in sketching?
Thank you.
Best regards,
Ransi
Help does work with this command, however, I couldn't find an explanation as to why what you mentioned would be greyed out. What I found by experiment is that if you choose construction lines then the scale types are greyed out but if you choose lines they are available. It still works with construction objects but it looks like your only choice is uniform scaling. Not sure why the developers made this distinction.
Hi rlkillian,
Thank you for the information. However, I still could not get it to work. Hope someone from Autodesk will clarify this anomaly?
Best regards,
Ransi
Sorry it didn't work. Maybe you can upload a screencast recording to show us what you are trying to do.
Hi Ransi,
There is not too much to clarify: it only has the capability to scale construction objects uniformly (in 3 directions). [Edit] Now that I think about it, there are probably limits to how arcs, circles, and splines can be scaled in 1 or 2 directions, and maybe those were never programmed.
So depending on what you are doing, one work around is to convert the construction objects to regular objects, scale them, and convert them back to construction objects. (You convert them by selecting the objects, right-click, Edit Attributes, and change the checkbox for "Construction Object".) This will work for lines. Circles and arcs would need to be scaled individually to get the desired effect of scaling in 1 or 2 directions.
As rlkillian indicated, attach a screencast or images of what you are trying to build, and someone may be able to provide other ideas.
Hi Everyone,
Can someone help me to construct the following?
I am trying to construct the cylindrical dumbbell that is shown in Figure 1. The dimensions are given in figure 2. Is it possible to generate the dumbbell with brick elements using the 2D end mesh (Figure 3) with Autodesk simulation draw functions?
Thank you.
Best regards
Ransi
Hi Ransi,
You do not want to create the end mesh (figure 3) and try to extrude it to create the dumbbell. You want to create the profile shown in figure 2 (half of the profile, actually) and revolve that around the Z axis.
There are multiple ways to do it. For example,
Another way to do it would as follows:
Once you know how to do it, it will take the same time to create the model as it did to read this reply.
