Wrong forum..
https://forums.autodesk.com/t5/simulation-mechanical-forums/bd-p/396
I have asked a moderator to move your post to the correct forum
Hi Marcin. Welcome to the Simulation Mechanical forum.
Can you provide some more information about the problem that you are having with the plastics library? For example,
Thanks.
John, I am having the same problem with the plastics material library. When I try to access the library from "element material selection", and select the plastics library, I get a message "unable to open database table algorplastics.mlb in c:\program files\autodesk\simulation2017\matlibs\mudflow. I have checked and the (3) required library files appear to be there. I tried to add a new library to attach, and I get "algorplastics is already attached as autodesk simulation plastics library" Any suggestions. My release 2016 did the same thing. TY for your time.
Craig Brockman
Oh, and John, I am using Windows 7, English version Sim Mechanical 2017.
