Dear all,
I have a question regarding the material model used in Autodesk Simulation Mechanical.
I am trying to model the stress caused by thermal expansion. I am using a custom defined material.
In the datasheet of the material i want to use i have two options;
- instantaneous coefficient of thermal expansion × 10−6 (mm/ mm/°C)
- mean coefficient of thermal expansion × 10−6 (mm/mm/°C) in going from 20°C to indicated temperature.
Can anyone tell me which one the program uses? I tried searching this and found nothing unfortunately.
Thank you in advance.
Kind Regards,
Arno
Hi arno. Welcome to the Sim Mech forum.
What type of analysis are you performing?
Hi John,
Thank you for reply.
The analysis I am performing is a Non-Linear analysis (MES or Static Stress with Non-Linear material model).
Good idea, i was thinking about drawing a 2D square (100x100mm or so) and then simply adding some temperatures to it to see the outcome.
2D or 3D should not make a difference for this small experiment i guess.
Just a thought; maybe you could add this to the Autodesk Simulation Mechanical documentation? I guess there will be more users with these kind of questions.
Kind Regards
Arno
To all,
I just ran a quick test with a 2D Simulation.
I modeled a square of 100mm by 100mm constraint(single direction) at two edges perpendicular to each other and simulated a temperature rise from
20 degrees C to 600 degrees C. I set the stress free reference temperature to 20 degrees C (as in the standard i am using).
I checked that the Von Mises stresses were near zero, so the square could expand freely in all directions without constraints.
The results of the simulation were within 99.4% of the tabulated values in the material properties standard, so John was right.
Autodesk Mechanical uses the Mean Coefficient of Thermal Expansion for the Non-Linear analysis.
Arno
