I have recently downloaded SM 2017 and am having a problem when I run a very simple cantilever beam. The part meshes fine and when I check the model it checks fine. When I run the analysis (linear static) it will run for a few minutes and then stop displaying "analysis failed". When I opened the ds file it states "Can not open geometry file [C:\Users\WIll\Desktop\FEA Models\junk.ds_data\1\ds.mod\group.esh]". When I look at the directory listed the file "group.esh" doesn't exist so it is easy to see why it can't find the file. So I guess my question is does anyone have an idea why the required file is not being generated?
Thanks.....
Rick
Hi Rick,
This is strange since the file group.esh is created when doing a Check Model. The question is, why does the file get deleted when you run the analysis.
