Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
303 Views, 1 Reply
won't finish
I have a 24 x24 x 24 inch box with  air flowing out via a fan. The problem wont finish and just quits with no errors??
1 REPLY 1
Joey.X
First double check boundary conditions, meshing etc on this model.
For the iteration number>1000, change pressure solver to  BCSLIB-EXT may help
Setup/Parameters/Solution/Formulation>>/Segregated Option/Solver control/BCSLIB-EXT(default is automatic).
You can apply this to another thread "2012 CFD Simulation Wont Finish" you started.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
