Lately, whenever I am running Sim Mech, I get these pop-ups that say "Please wait while Windows configures Autodesk Inventor 2015".
The first few times I got this, I let it run, thinking it would do it's thing and then it would be done. But, It keeps coming back. So, now I just hit cancel, so I don't have to wait for it.
But, I get this 20 or 40 times a day.
What does it want that it's not getting?
Solved by Andrew.Sartorelli. Go to Solution.
Hi Steve,
Does the popup say "Please wait while Windows configures Inventor" or does it say "Simulation Mechanical" ? I can walk you through the steps to fix the issue if it says "Simulation Mechanical". Do you have a support subscription? If so, can you please direct message me your express service id and I will get a case set up. The process requires making a manual modification to the system's registry so its a bit tricky.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
No change.
I tried running as administrator. I let Windows do whatever it was trying to do twice, but I still get the pop-ups.
Next I tried logging into another account (one with administrator proveleges). I opened a small model in Simulation, and ran an analysis. No pop-ups this time.
I retirned to my own account, Opened Simulation, and the pop-ups are still there.
Hi Steve,
Can you please use Reigstry Editor (regedit.exe) to look at the following registry key, HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0BE1E073FE407084B86554265447378B. There should be one or several items within this location, please attach a screenshot of what you see.
Ok, that seem to have solved the problem. Thank you.
Now, what do you think actually happened here?
