Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Why von mises stress similar
1 REPLY 1
354 Views, 1 Reply
When I run analysis drop test  model with high level differrent (H1=180mm, H2=90mm, H3=50mm) but von mises stress  same as. So I do not understand. Can you help me? Drop test 1.jpg
1 REPLY 1
S.LI
Do you mean the peak value at the impact moment?
You need to turn on the option to output results at all steps to catch that critical time point.
Otherwise, you may only see the body when it's flying in air (before and after touch moment).
If this response answers your concern, please mark it as "solved".
