Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Why the ”Load from File“can't use?
3 REPLIES 3
347 Views, 3 Replies
   Why the ”Load from File“can't  used in "Steady-Coupled Fluid Flow and Thermal" ansys type in Autodesk simulation Mechanical 2013?
   For example,I want using voltage results or the joule heat as the load of temperature in  "Steady-Coupled Fluid Flow and Thermal" ansys type,but I found use temperature field results as the load conditions is not possible
 thanks,
3 REPLIES 3
ilyas_drawbridge
Hi, Mechanical 2013 does not have fluid flow analysis, I assume you are using Multiphysics 2013. If I'm not mistaken, thermal results can be imported to a fluid flow analysis from the Analysis Parameters dialog inside the Thermal tab.
Regards
IIyas
in reply to: ilyas_drawbridge
Hi,IIyas
   Thanks for your reply!
   And I tried to importe the  thermal results to a fluid flow analysis from the Analysis Parameters dialog inside the Thermal tab ,but show "error".
Attached is a 3D model file,I want to know whether setting problem or application problem.
Below is my calculation about process:
stp1:electrostatic current and voltage
         voltage :0v,5v
stp2:fluid flow
jiaming0503
ilyas_drawbridge
Hi, I don't know what the error is about. But if you want to check whether you have set it up correctly, post an archive of your model, someone in this forum might have a look.
Regarding the analysis itself, if the cable is exposed to ambient air, perhaps you can exclude the air from the analysis and perform electrostatic analysis followed by thermal analysis while adding convection load to the outer surface of the plastic to account for the air.
If the air is jacketing the cable, then perhaps an electrostatic analysis followed by a fluid flow analysis followed by thermal analysis would be best as I don't think the bouyancy effect would have much effect then. Just my thought.
Regards
Ilyas
