Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Why pin joint (truss element) collapsed?
2 REPLIES 2
ccz90
506 Views, 2 Replies
I use pin joint setting in my numerical model. But the solver program always shows lots of warning messages like:
*** Warning : Truss element collapsed!
                      Numerical exception may occur
                      Element number=51
                      Original element length =11.87
                      Current element length=NaN
 then the time step is reduced again and again, and the model seems difficult to converge.
Why and how to avoid the problems? Thanks!
        CCZ90
2 REPLIES 2
AstroJohnPE
in reply to: ccz90
It sounds like a numerical problem in the MES simulation, so I suggest trying a smaller time step just before this event occurs. (online wiki Help) I am hoping that a different calculation path will avoid the problem. (NaN stands for "Not a Number", so something is occurring mathematically.)
Otherwise,
  1. What material model are you using for the trusses?
  2. What is the stiffness of the trusses? (Cross-sectional area and modulus of elasticity)
  3. What step does this occur on?
  4. What is the force in the truss before it collapses? ("Results Contours > Other Results > Element Forces > Axial Force")
  5. What element type is the truss connected to?
ccz90
in reply to: AstroJohnPE
  • What material model are you using for the trusses?
      Linear
  • What is the stiffness of the trusses? (Cross-sectional area and modulus of elasticity)
      Cross-sectional area from 7~300 mm^2 , E= the defacut material parameters from autodesk material library
  • What step does this occur on?
      Changeful. It maybe at the bigining or the process of the calculation.
  • What is the force in the truss before it collapses? ("Results Contours > Other Results > Element Forces > Axial Force")
     In some cases, the forcees are very small, 7 ~ -4.9N
  • What element type is the truss connected to?
    Brick (isotropic elastic steel)
I have used a smaller time step with bigining of 1~0.1 ms, and the solver might reduce the time step more. The
warning messages still display  randomly.
        Ccz90
