Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Weird Error while trying to mesh
3 REPLIES 3
759 Views, 3 Replies
I am trying to mesh a model, it is a decent size model element size(~1.5 million elements) and everything goes fine until it finishes. Once it finishes it gives me a warning that the mesh did not complete but gives me this in the error box
"No Input Nodes in FEM File"
anyone have any clue what this means and or how to fix it? I am wasting a lot of time trying to get this model to mesh
Thank you
3 REPLIES 3
Does anyone have any idea what this error means and how to fix it? I have submitted the error report to autodesk several times. Is there someone at autodesk I can send the model to see if they can find out what is wrong with it?
Thank you
can you provide more info about analysis type,some images like that?
I'm getting this same error with a very simple geometry and a coarse mesh. I have previously meshed this geometry with these settings with these with no problems. Was there ever a solution to this?
Attached is an archive file in a zip file. Related note to Autodesk web developers, the .ach file extension is what Simulation Mechanical uses to make archive files. Add it to your list of accepted file types for file attachment on the forums.
Garrett
--- Update ---
I got this to mesh after I restarted my computer. This is a band-aid, not a solution.
Tags (1)
