i have a model that performs as it should, however I am unable to visual the displacement. The contour plots work just fine but when I go to show the displacement the model does not move. I have even changed the scale factor all the way up to 100% and I still get zero movement. The displacements are not very large with a max displacement of 0.09" so the model is acting as it should I just have no way to see how it moves. Has anyone experienced this? any idea how to fix it? It is a rather large 3D Model but solves in about an hour, so it is not extremely large.
Any ideas?
Thank you
well I think I found the issue....but no idea how to fix it....there seems to be a bunch of nodes that have very large displacement, but they do not seem to be attached to any elements. Any way to delete these nodes? or any idea why they are there?
Hi BAT,
Instead of trying to use the percentage to show the displacement, change to using an absolute value and enter a scale factor. 0.09 inches times X will make the displacement large enough to see in a model of size Y.
Otherwise, an image or description of the model would be helpful. For example,
Yeah i tried both, actual and percentage...
I found I was able to select some nodes away from the model that when they were selected I could see them displacing when i animated the model. So these nodes that were created are not joined to anything within the model. But i have no way to select them(outside of results viewer) so no way to delete them.
Analysis type is Static Stress Linear ,
When you say size do you mean number of elements? there are 771,000 elements and 532,000 Nodes
the model is located near 0,0,0
Element type is Brick, so Hex and Tet, there are no springs or beams in the model
The types of contact are Bonded and Sliding with no seperation
If there was only a way to hide those nodes or delete them....because they are what is showing the displacement
I got this to work by remeshing it with a slightly smaller mesh size...not really sure how I got it to act that way...but at least it is working now
