Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
von Mises stress scaling in results
2 REPLIES 2
edward.doughty
1031 Views, 2 Replies
Is it possible to get the von Mises stress scale in the results to be a specific colour for a specific stress. I am trying to show the stress difference between two versions of a component, the stress in Yoke-version2 is half that of  Yoke-version1 but the colour scale is set against the maximum stress so Yoke-version2 looks like it has higher stresses, see images. In the Yoke-version2 the light blue equates to 88N/mm sq and in the Yoke-version1 it equates to 186N/mm sq, ideally I would like 88N/mm sq to be the same colour in both sets of results.
2 REPLIES 2
Go to the Results Contours ribbon and click Legend Properties, Setup, Range Settings. That will allow you to set the legend to any scale you want. If you’re using a version prior to 2012 I think it was called display properties instead of legend.
Thanks, just what I wanted.
