Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Volume Averaged Stresses in Simulation Mechanical
3 REPLIES 3
COzcan
557 Views, 3 Replies
When trying to calculate volume averaged stresses, one can select "inquire results" and first: select nodes and then select elements which includes the nodes to get a volume averaged stress value. Is there a way to just select parts and or elements to get volume averaged stress values?
The wait times can be improved on a later release as a suggestion.
Best Regards...
Can
Can Ozcan
AKRO Engineering
can.ozcan@akroengineering.com | www.akroengineering.com
3 REPLIES 3
ilyas_drawbridge
in reply to: COzcan
Hi Can,
I think you can select the parts that you are interested with using Selection>Select>Parts and then right-click>Select Subentities>Nodes to select all the nodes in the part. Then, you can inquire the results via Current Results and use the Mean operation to compute the average stress. Depending on the number of nodes, this may take some time.
Regards
Ilyas
COzcan
in reply to: ilyas_drawbridge
Hi Ilyas;
Thanks for the reply. However what I am looking for is the volume averaging, not the mean value. Mean is easy to calculate which is min plus max divided by 2. Volume averaging requires calculation of element volume and a summation over all selected elements.
Best...
Can
Can Ozcan
AKRO Engineering
AstroJohnPE
in reply to: COzcan
I suspect the "mean" that Ilyas is referring to is (sum of stress at all nodes)/(number of nodes) which is different than (maximum + minimum stress)/2. Naturally, this is still not the same as averaging based on the volume.
Some results can be averaged based on the volume or mass. If you open the "Results Inquire > Inquire > Current Results" window, select an element in the model, and if the results are shown (at the nodes on those elements), then you can get a volume weighted average. I know that temperature can be averaged based on the volume, but stress cannot.
Before you can get the volume weighted average, you need to run the "Analysis > Analysis > Weight and Center of Gravity" command. Then the "Inquire Results" dialog's "Summary" pull-down has the option "Mean weighted by volume".
Since the software will not do the calculation automatically, you could perform the calculation in a spreadsheet. First, display the "Results Contours > Other Results > Element Properties > Volume", select the elements of interest, inquire on those results, and "Save Values" to a .csv file. Then use "right-click > Select Subentities > Nodes" to get the nodes on the same elements, display the stress contour, inquire on those results, and "Save Values" to a .csv file. Then in a spreadsheet, you can create a lookup formula to put the volume of the element next to the stress at each node and perform the volume averaging calculation.
