With Ver 2012 SP1, I do not get stress results for plate or brick elements. Model consists of plates, bricks, and beams. I do get stress results for beam elements.
I did get plate stresses with Ver 2011. I have not gone back to that version as I am hoping that I just need check a box or something. FEM file is 68 mb with modal and response spectrum scenarios, so I have not attached it.
Any help appreciated with limited info I have provided so far.
Wondering if it is a bug.
..........John Sherow
Solved by JohnD.Sherow2645. Go to Solution.
It seems to be a bug from the new Ribbon style UI. You can disable it by unchecking the "Ribbon Style" box from "Tools"->"Application Options"->"General Information". Hope it solves your problem.
