Simulation Mechanical and Multiphysics
Member
0 Kudos
Vector Plot
298 Views, 3 Replies
08-16-2010 12:31 PM
Does anyone know how to change the size of the vector's displayed in the vector plots?
Employee
0 Kudos
Re: Vector Plot
08-16-2010 01:04 PM in reply to: mandelbaum.diego
In the Results environment, use the Display Options: Plot Settings... command and go to the Vector Plots tab.  You can change the length of the arrows and the size of the arrow heads.
Active Member
0 Kudos
Re: Vector Plot
03-30-2013 02:46 PM in reply to: mandelbaum.diego
There is no vector plot option in my result... how I can enable to showing vector plot?
129 Kudos
Re: Vector Plot
03-31-2013 06:26 PM in reply to: Nastran
Hi Nastran,
What type of result are you trying to show a vector plot for?
What options do you see available for that type of result?
What version of Simulation Mechanical/Multiphysics are you using?
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
Simulation Mechanical user since Dec 1997
