In the Results environment, use the Display Options: Plot Settings... command and go to the Vector Plots tab. You can change the length of the arrows and the size of the arrow heads.
Hi Nastran,
What type of result are you trying to show a vector plot for?
What options do you see available for that type of result?
What version of Simulation Mechanical/Multiphysics are you using?
