my aim is a distributed (variable) load in a bearing. I haven't found a way to create such a load.
Do I need local coordinate systems ?
What's the right equation ?
Thanks in advance.
Solved by S.LI. Go to Solution.
In Help, please search "variable loads". You might find more interesting information there.
Is the equation not available in the handbook? I am guessing that the variable surface load should be set to "Normal to surface", but the equation itself, I'm not sure. Is it a Hertzian contact pressure? I don't think it's any kind of sinus function.
I've attached an image of the simplified bearing. You can see the global coord and the local coord (hand drawn).
The model is symmetrical so there's only the half of it.
The total force of 400 kN should work in global -z. The force is distributed over the half of the surface (there is a little cut to separate the surface). In local z-direction (bearing axis) the load is constant. In local x- and y.direction the load depends on the angle. At the edge of the small cut the force is 'zero' and for R = (-local x) it's a maximum. The applied load is a pressure because I apply the load to a surface.
Any ideas how to express this problem in an equation ?
Parameters:
Fmax=400 kN in local -x or global -z
bearing radius= 112,5 mm
bearing width=160 mm
Sorry, I don't know enough tribology to answer your question. Hopefully someone else does.
/Björn
To avoid misunderstandings...
It has nothing to do with tribology - simply: distributed load in a bearing.
Here is my thought about the equation.
