Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Use forces/pressure from fluid flow in static analysis?
1 REPLY 1
maxedvardsson6198
453 Views, 1 Reply
Hi all!
As the subject suggests, can you directly use the result file from a fluid flow  to calculate the stresses, etc... in a static analysis of same model (as you can with a previous thermal/electrical analysis in static analysis)?
For example, could you calculate the stresses in the wall in the "ball valve" tutorial or do you have to model it differently?
Thx
Max
1 REPLY 1
S.LI
in reply to: maxedvardsson6198
As shown in the attached screenshot, you can import force/pressure from fluid flow to static analysis.
If this response answers your concern, please mark it as "solved".
