Hi all!
As the subject suggests, can you directly use the result file from a fluid flow to calculate the stresses, etc... in a static analysis of same model (as you can with a previous thermal/electrical analysis in static analysis)?
For example, could you calculate the stresses in the wall in the "ball valve" tutorial or do you have to model it differently?
Thx
Max
As shown in the attached screenshot, you can import force/pressure from fluid flow to static analysis.
