Each time when I want to open a *.ach file. The warning message "Unable to open file: *.fem does not exist." will appear. In fact, the fem file can be find at the same file folder. How to solve the problem?Thanks.
Ccz90
I do not have an answer Ccz90, but a question to help diagnose the problem. After it fails to open the archive, what happens if you try to open the .fem file? Does that also fail?
My only idea is that there is something related to the path where the model is stored.
Algor(V23.1) really develops a fem file with the same file title. For example, test.ach ---> test.fem I must open the fem file by hand each time, and the fem file can work as usual .
The problem is still there even I reinstall the program or format my computer.I don't know why???
Ccz90
It is interesting. I am wondering how the ACH file was generated. There are two ways I usually used:
(1) Use ALGOR to generate an ACH file, where the model should be opened in ALGOR.
(2) Select the FEM file and the File folder, right click and select "Add to archive". After that, choose Archieve format as "ZIP", and define Archieve name as "Name.ach". Note that here Archieve format cannot be "RAR".
Could you test the following things:
(1) After manualy open FEM file in ALGOR, please use the "Archieve->Create" command to create a new ACH file. And then check whether your can open it.
(2) Select the FEM file and the File folder, right click and select "Add to archive". After that, choose Archieve format as "ZIP", and define Archieve name as "Name.ach". And then check whether your can open it.
-Shoubing
