i was wonder to know if Algor simulation is able to analyze turbine analysis, i mean hot air flow via nozzle into turbine blades and rotation of turbine shaft/rotor to evaluate output parameters like mechanical power, velocity etc, under loads.
Solved by Joey.X. Go to Solution.
Try modelling in fluid flow - Multiple rotating frame of reference(MRF), refer to online help in special modeling with MRF.
Note it has no direct mechanical power and under loads output, user needs evaluate them by rotating speed input and velocity and pressure output.
borikg, we should talk sometime. Steam turbine component simulation is what I do and you're only other user I've found so far with similar interest.
