Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Total heat loss per time step.
1 REPLY 1
360 Views, 1 Reply
Using Autodesk Mechanical Simulation.  I would like to know if there is an easy way to get the total amount of heat lost per time step for a simple cooling analysis.  I have a model that begins at a high temperature with the ambient temperature being much lower, and the part is allowed to cool over a long period of time.  I need to know how much heat was lost from the model at each time step.  My model is a highly complex shape with varying thicknesses, so going through and calculating an average heat loss from all the different regions is not feasible.
1 REPLY 1
AstroJohnPE
Hi jr1287,
I do not know of an automatic method. But if your material properties are independent of temperature, the software can calculate the equilibrium temperature. You can then calculate the heat loss from Q = mass*cp*dTemp. Search the documentation for "Equilibrium Temperature", and then go to the page named "Current Results".
