Hi everyboy,
I read the thin on line help manual we have and the forum to find some informations about the different process used to smooth constraints fields in the result tab, but was unsuccessfull.
Gaps are so huge between different methods, I wonder if this option provides reliable results to exploit.
Solved by AstroJohnPE. Go to Solution.
Hi Ju_brl,
I believe that you are asking about the command "Results Contours > Settings > Smooth Results" and "Smoothing Options" which are described on the pages "Results Options Menu" and "Results Environment" in the Wiki Help. Most of the options were included simply because it was easy to program them (for example, "Maximum", "Minimum", "Sum" type of smoothing functions) or because they were requested by a customer ("Smooth before applying operators"). I use the defaults 99.9% of the time because those are the ones that make sense.
I have used these on rare occasions:
If you have any other questions, please clarify what type of result you are asking about, what you are trying to do with that results, the type of analysis, and the type of element.
This absolutely enough for.
Thank you very much for your help John.
Regards.
