Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Thermal expansion model
2 REPLIES 2
misterblobby
766 Views, 2 Replies
Hope someone is willing to help me here - I am sure this is a very easy question!
I am playing with an evaluation version of Algor Simulation and am trying to do a thermal expansion analysis on a simple part.
I have set the model up by assigning a rigid surface boundary condition and part temperature of 30 degrees, with a stress free reference temperature of zero degrees in the element definition and a linear static stress analysis type.
This seems to match some webcast tutorial I found, but after running the simulation I get zeroes across all result tables. What am I doing wrong?
2 REPLIES 2
PipePakPat
in reply to: misterblobby
Brett,
You may need to define a non-zero multiplier for thermal loading from within the Analysis Parameter's "Multipliers" tab.
Pat Tessaro, P.E.
Autodesk Inc.
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
misterblobby
Thanks Pat,
That was the problem and it's working fine now.
