It looks like I should be able to use temperature dependent material propeties for stress analysis of a pressure vessel. Is that true? Thanks.
I believe so.
After the model is in simulation environment, both shell and solid elements support temperature dependent material models.
Does the material library have temperature dependent material properties or do I have to find a source and enter them myself? Thanks.
I bet you need input it by yourself.
