Discussion Groups
Simulation Mechanical and Multiphysics
Employee
Sualp.Ozel
Tell us your ideas for new features and enhancements
1757 Views, 8 Replies
02-14-2013 02:19 PM
Use the following link to post your ideas for new features and enhancements & vote on requests/ideas from other Simulation Mechanical users.
http://forums.autodesk.com/t5/Simulation-Mechanical-Idea/idb-p/81
The development team will work on implementing features/enhancements/ideas with the highest number of votes...
-Sualp
Please use plain text.
Active Contributor
nosborne
Additional Tensile/Compressive Stress Plot
02-15-2013 06:07 AM in reply to: Sualp.Ozel
I would like to be able to plot the maximum of Maximum Prinicipal and Minimum Principal stresses on the same stress plot. For example the plot scale would be set at -30 ksi to 30 ksi and it would be obvious which areas of the model have high tensile stress and which areas have high compressive stress.
Maybe there is a way to do this currently with custom results but I have not been able to do it.
Employee
Sualp.Ozel
Re: Additional Tensile/Compressive Stress Plot
02-15-2013 06:13 AM in reply to: nosborne
Please post such ideas to the following web page: IDEA STATION  :smileyvery-happy:
Valued Contributor
dharhay
Re: Tell us your ideas for new features and enhancements
02-28-2013 04:51 AM in reply to: Sualp.Ozel
Thats a great question.  My short wish list:
1) The program to be reconfigured so that when you kill a meshing session, kill an analysis the program QUICKLY,
completely terminates such that you can proceed with your changes.
2) All windows are closed at the same location ie at the lower RH of the window is where the box to click would be located.
3) A part in the model can be updated from the solid model instead of re-importing the entire model and re-establishing all the node based features that were lost.
4) The bugs that I found and were reported to the developers were actually corrected.
I am going to stop there. Thanks.
Dave H
Active Member
0785725
04-09-2013 11:35 AM in reply to: Sualp.Ozel
It would be very nice if rules on uploading files were not so strict.
I have already tried a few times, but it's almost impossible to upload a archive, while this software produces a whole lot of strange messages, like:"**** Non-positive diagonal entry detected in ILU method
      switch to SSOR Preconditioner".
(beats the **** out of me :smileysad:  )
Reagrds, Floris
Valued Contributor
saainsworth
12-11-2013 08:26 PM in reply to: Sualp.Ozel
Please fix the Nodal Weights dialog.  It has a number of issues that make it difficult to use.
1) A better name would be "Nodal Mass" since that is what is really being added.
2) The units for Mass moment of inertia are not correct.  When set to mass You get N*s^2*m which is a force unit.
When set to force you get N*m^2 which is not a correct unit of inertia. The correct unit is kg*m^2 -- a mass unit.  The English
units are similarly messed up.
3) When switching unit systems the values update.  However, when switching from Mass to Force units within the dialog it does
calculate the conversion.  If someone enters a value and then switches the input mode the value is then wrong.  This makes no sense
and certainly is not would be expected in quality software.
4) Provide an option to specify the mass moment of inertia about either the model coordinate system or the center of mass (at the node).
Currently is not clear which is being specified.  The help file does not clarify this.
New Member
scottminer49
05-15-2014 07:28 AM in reply to: Sualp.Ozel
I would love if you could make it so I can view the colorized results while I move rotate around the model, not just when I stop moving it.
-Scott
Valued Mentor
AstroJohnPE
05-16-2014 06:31 AM in reply to: scottminer49
That function already exists Scott: "Results Options > View > No Shading When Moving Model". I use it so often that I placed it on my Quick Access Toolbar.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
Leonel16
06-30-2014 01:14 AM in reply to: AstroJohnPE
I would love to have an option wherein you can explode the model(parts) at SimMech environement so that it can be easily bond surface and do other stuff.
More power Autodesk!
Leonel16
