Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Suspect FEA results
1 REPLY 1
CPEProjE
792 Views, 1 Reply
Suspect FEA results
Forum,
Material (Color):
  • W12x96 A992 (Purple)
  • W6x25 A992 (Orange)
  • W8x31 A992 (Light Blue)
  • W6x9 A992 (light grey)
  • 0.375 in. THK A36 plate
I am having a problem with an analysis I can't seem to figure out.  When I ran the FEA last week, I was only get deflections of 1.5 - 5 inches.  After adding in additional W6x9 beam supports depicted in grey beneath the 0.375" A36 plate steel and running the FEA again, I get over 10" of deflection (See FEA below).
The picture below is how the subassembly comes into SimMech when pushed from Fusion
I sectioned the plate in Fusion; the section of A36 plate in bright yellow and orange in the pictures shows where the surface pressure of -5.0 psi of water having a total weight of 131,000 lbs for the volume above this area section and surface temperature of 195 deg F were applied
I fixed (x,y,z) the W12x96 in all directions on the bottom of each in this partial assembly to represent them actually resting on level and reinforced ground.  I also employed gravity in the -Y direction to account for the weight of the partial structure.
The W8x31 and W6x9 are supposed to be supporting the 0.375" thick A36 plate.  What I see as a problem after the analysis is completed is that there is over 1.5 - 10" + deflection in the plate but virtually no deflection (0.000547 in.) in the cross beams.
How I got to the -5 psi loading is as follows:
  • 176 in. x 148.25 in. = 26092 in^2   (181.194 ft^2)     AREA UNDER LOAD
  • 181.194 ft^2 x 11.5 ft (height of the water in that volume space) =  2083.74 ft^3   VOLUME OF WATER
  • 2083.74 ft^3 x 62.4 lb/ft^3 = 130,025 lbs      WEIGHT OF WATER IN THAT AREA/VOLUME
  • 130,025 lbs / 26092 in^2  = 4.983 lb/in^2 (psi)   WEIGHT LOAD PER IN.^2 OF WATER IN THAT AREA/VOLUME
Now given that there is an automatically assumed bonding between parts in contact, I can't understand why there is no deflection showing for the beams.  Should I be ignoring gravity since the weight is already accounted for in material and element definition?
Thank you in advance.  If it'll help diagnose, I've included the NotePad results of the latest run which had one (1) WARNING:
 Autodesk (R) Simulation Static Stress with Linear Material Models
 Version 2014.01.00.0025-W64/X64 26-Jul-2013
 Copyright (c) 2013, Autodesk, Inc. All rights reserved.
                          DATE: JANUARY 30, 2014
                          TIME: 01:54 PM
                   INPUT MODEL: C:\FEA\XXXXXXX_FLOOR_FEA.ds_data\1\ds
                    PROGRAM VERSION: 201401000025
            alg-win-x64.dll VERSION: 201401000025
       agsdb_ar-win-x64.dll VERSION: 201401000025
      algconfig-win-x64.dll VERSION: 201401000025
 solvercallback-win-x64.dll VERSION: 201401000025
               amgsolve.exe VERSION:    360000000
 **** Model Unit System Settings:
       Unit System              : English (in)
       Force                    : lbf
       Length                   : in
       Time                     : s
       Temperature (Absolute)   : deg F (R)
       Thermal Energy           : in*lbf
       Voltage                  : V
       Current                  : A
       Electrical Resistance    : ohm
       Mass                     : lbf*s^2/in
1**** CONTROL INFORMATION
      number of node points          (NUMNP)   =        402582
      number of element types        (NELTYP)  =            22
      number of load cases           (LL)      =             1
      number of frequencies          (NF)      =             0
      analysis type code             (NDYN)    =             0
      equations per block            (KEQB)    =             0
      bandwidth minimization flag    (MINBND)  =            -1
      gravitational constant         (GRAV)    =    3.8640E+02
      number of equations            (NEQ)     =       2272386
 **** PRINT OF NODAL DATA SUPPRESSED
 **** PRINT OF EQUATION NUMBERS SUPPRESSED
 **** Part     1: plate (shell) elements
 **** The maximum warp angle =  4.4733E+00 degrees
      There are 130 quadrilateral elements over tolerance :  1.0000E-01
      Total 1406 triangle elements.
 **** PRINT OF TYPE-6 ELEMENT DATA SUPPRESSED
 **** Part     2: plate (shell) elements
 **** The maximum warp angle =  6.0707E+00 degrees
      There are 493 quadrilateral elements over tolerance :  1.0000E-01
      Total 1124 triangle elements.
 **** Part     3: plate (shell) elements
 **** The maximum warp angle =  5.3709E+00 degrees
      There are 233 quadrilateral elements over tolerance :  1.0000E-01
      Total 1338 triangle elements.
 **** Part     4: plate (shell) elements
 **** The maximum warp angle =  1.9915E+00 degrees
      There are 189 quadrilateral elements over tolerance :  1.0000E-01
      Total 106 triangle elements.
 **** Part     5: plate (shell) elements
 **** The maximum warp angle =  4.4745E+00 degrees
      There are 12 quadrilateral elements over tolerance :  1.0000E-01
      Total 1922 triangle elements.
 **** Part    26: plate (shell) elements
 **** The maximum warp angle =  4.4068E+00 degrees
      There are 35 quadrilateral elements over tolerance :  1.0000E-01
      Total 50 triangle elements.
 **** Part    27: plate (shell) elements
 **** The maximum warp angle =  4.4041E+00 degrees
      There are 19 quadrilateral elements over tolerance :  1.0000E-01
      Total 46 triangle elements.
 **** Part    34: plate (shell) elements
 **** The maximum warp angle =  5.5276E+00 degrees
      There are 408 quadrilateral elements over tolerance :  1.0000E-01
      Total 572 triangle elements.
 **** Part    35: plate (shell) elements
 **** The maximum warp angle =  5.3552E+00 degrees
      There are 519 quadrilateral elements over tolerance :  1.0000E-01
      Total 350 triangle elements.
 **** Part    36: plate (shell) elements
 **** The maximum warp angle =  4.6745E+00 degrees
      There are 518 quadrilateral elements over tolerance :  1.0000E-01
      Total 348 triangle elements.
 **** Part    37: plate (shell) elements
 **** The maximum warp angle =  1.2695E+00 degrees
      There are 243 quadrilateral elements over tolerance :  1.0000E-01
      Total 94 triangle elements.
 **** Part    38: plate (shell) elements
 **** The maximum warp angle =  4.2532E+00 degrees
      There are 246 quadrilateral elements over tolerance :  1.0000E-01
      Total 100 triangle elements.
 **** Part    51: plate (shell) elements
 **** The maximum warp angle =  1.8545E+00 degrees
      There are 1 quadrilateral elements over tolerance :  1.0000E-01
      Total 2574 triangle elements.
 **** Part    52: plate (shell) elements
 **** The maximum warp angle =  5.3240E-07 degrees
      There are 0 quadrilateral elements over tolerance :  1.0000E-01
      Total 2 triangle elements.
 **** Part    53: plate (shell) elements
 **** The maximum warp angle =  1.6084E-06 degrees
 **** Part    54: plate (shell) elements
 **** The maximum warp angle =  1.3634E-10 degrees
      Total 8 triangle elements.
 **** Part    55: plate (shell) elements
 **** The maximum warp angle =  8.7709E-11 degrees
 **** Part    56: plate (shell) elements
 **** Part    57: plate (shell) elements
 **** Part    58: plate (shell) elements
 **** The maximum warp angle =  5.3261E-07 degrees
 **** Part    59: plate (shell) elements
 **** The maximum warp angle =  1.6085E-06 degrees
 **** Part    60: plate (shell) elements
 **** The maximum warp angle =  1.4390E-10 degrees
      Total 10 triangle elements.
 **** Hard disk file size information for processor:
      Available hard disk space on current drive =1703585.625 megabytes
      Gravity direction vector =  0.0000E+00 -1.0000E+00  0.0000E+00
1**** ELEMENT LOAD MULTIPLIERS
       load case     Pressure   Gravity  Displacement  Thermal  Electrical
          1         1.000E+00  1.000E+00  1.000E+00  0.000E+00  0.000E+00
      Centrifugal force / angular acceleration
      load case     rot.rate   ang.acc.
          1         0.000E+00  0.000E+00
 **** Symbolic Assembly Using the Row-Hits Matrix Profile ...
 **** Number of equations                 = 2272386
      Estimated maximum bandwidth         = 287
      Estimated triangle matrix nonzeroes = 120864045
      Symbolically assembled nonzeros     = 62625075
 **** Real Sparse Matrix Assembly ...
1**** STIFFNESS MATRIX PARAMETERS
      minimum non-zero diagonal element =           1.0393E+02
      maximum diagonal element          =           2.3255E+13
      maximum/minimum                   =           2.2376E+11
      average diagonal element          =           4.5301E+08
      warning: max/min stiffness ratio =            2.2376E+11
               maximum stiffness =  2.325452E+13 at eqn#204920, node=41818, DOF=Ty
               minimum stiffness =  1.039269E+02 at eqn#2014558, node=359611, DOF=Rx
      in the upper triangle:
      number of entries in the profile    = 120864045
      number of nonzeros                  = 43264318
 **** Sparse Matrix Assembled
 **** Invoking Parallel BCSLIB-EXT Sparse Solver...
 **** Load Cases 1
      BCSLIB-EXT solver memory status:
      in-core memory requirement (MB) =         7399.58
      minimum memory requirement (MB) =          642.16
           user specified memory (MB) =        24422.05
       available physical memory (MB) =        24422.05
        available virtual memory (MB) =        87464.03
      memory currently allocated (MB) =         7399.58
 **** End Sparse Solver Solution
               Reaction Sums and Maxima for Load Case       1
      Sum of applied forces
         X-Force     Y-Force     Z-Force    X-Moment    Y-Moment    Z-Moment
     -1.2714E-04 -1.6276E+05 -2.7695E-03  1.2899E-02  1.1758E-02  9.2720E-02
      Sum of reactions
      8.0048E-05  4.7004E-04  7.4947E-06  2.7131E+04  9.6315E+01  1.4256E+05
      Sum of residuals
     -4.7091E-05 -1.6276E+05 -2.7620E-03  2.7131E+04  9.6327E+01  1.4256E+05
      Sum of unfixed direction residuals
     -1.6005E-05  1.4380E-04  4.8936E-05  1.8817E-06  1.8582E-06  5.3725E-07
      Largest applied forces and moments
            Node        Node        Node        Node        Node        Node
           26801      306072       19344       50150       62829       62829
     -1.8079E-02 -7.8434E+01  1.1604E-02 -1.8536E-03  1.2322E-03  1.7259E-03
      Largest nodal reactions
          122562       50959       50958       50959      122563      253224
     -1.3406E+04 -3.1761E+03 -1.1810E+04  5.8549E+03  2.3227E+02  1.8166E+03
      Largest nodal residuals
     -1.3406E+04 -3.1763E+03 -1.1810E+04  5.8549E+03  2.3227E+02  1.8166E+03
      Largest unfixed direction residuals
           90501      103024       86954      103044       86954       90501
     -7.2988E-06  4.8633E-05  4.3924E-05 -2.2595E-06  2.6675E-06  1.6831E-06
1**** TEMPORARY FILE STORAGE (MEGABYTES)
       UNIT NO.  7 :     17.337
       UNIT NO.  8 :     18.429
       UNIT NO.  9 :      0.000
       UNIT NO. 10 :      0.000
       UNIT NO. 11 :      0.000
       UNIT NO. 12 :     17.337
       UNIT NO. 13 :     17.378
       UNIT NO. 14 :      0.000
       UNIT NO. 15 :      0.000
       UNIT NO. 17 :      0.000
       UNIT NO. 50 :    423.170
       UNIT NO. 51 :     56.031
       UNIT NO. 52 :   1048.503
       UNIT NO. 54 :      8.668
       UNIT NO. 55 :    165.040
       UNIT NO. 56 :    330.081
       UNIT NO. 57 :    330.081
       UNIT NO. 58 :      0.000
       UNIT NO. 59 :      0.000
       TOTAL       :   2432.054 Megabytes
1 REPLY 1
AstroJohnPE
in reply to: CPEProjE
Hi CPEProjE,
If the plate is deflecting but the beams are not, it is because the plate is not connected to the beams. One of these may be the problem:
  1. The CAD model has a gap between the plate and the beams which is larger than the mesh matching tolerance, so the parts are not bonded. (Bonding only occurs in linear stress if the gap between parts is 0.)
  2. The mesh type is wrong to get bonding to occur. For example, a midplane mesh would put the elements at the mid-thickness of each part, so the gap between the plate and beam would be 1/2*(plate thickness + flange thickness), and bonding will not occur with a gap.
  3. The mesh type is wrong for the geometry. It looks like you started with a solid model but ended up with plate elements. If you chose the "plate/shell" type of mesh for a solid model, then you ended up with hollow shapes for each part. Search the documentation for the page titled "Model Mesh Settings" for examples of the three types of mesh (solid, midplane, plate/shell) on a CAD solid model.
Good Luck.
