Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Surfaces will not contact...
10 REPLIES 10
Message 1 of 11
isaacc
1270 Views, 10 Replies
The surfaces in my model will not contact. I have tried selecting just the two faces, the whole parts, etc. I have done linear, nonlinear, and MES... I have no idea why they keeps passing through each other.
10 REPLIES 10
Message 2 of 11
zhuangs
in reply to: isaacc
You might upload the model for us to easilly investige it.
-Shoubing
Message 3 of 11
isaacc
in reply to: zhuangs
Ok I will as soon as I get a chance! Could it be because the part is not actually touching, just exaggerated to touch?
Message 4 of 11
zhuangs
in reply to: isaacc
It seems that the contact is not detected.  I am wondering whether the contact is well set up between the surface really in contact.
-Shoubing
Message 5 of 11
in reply to: isaacc
I have the same problem.
I'm working on a FEA of a climbing carabiner (oval-shaped; one side of the oval is a gate which opens and closes allowing a rope into the carabiner).
The gate of the 'biner has a hook which attaches to the "nose" of mainbody/biner.  However, this hook does not engage until the biner slightly deforms.
I've attempted to use the separation/no sliding contact option, but the solver behaves as if there is no contact occuring.  The nose simply passes right through the gate hook.
The initial gap of the system is about 0.040".  That means the nose must deflect 0.040" before the contact surface comes into play.
Any help would be greatly appreciated!
Message 6 of 11
AstroJohnPE
Hi charsguo and isaacc,
I suggest that both of you create an archive of the models and attach them to the reply. It would make it much easier to find the probem.
See this thread for instructions on archiving.
Message 7 of 11
AstroJohnPE
in reply to: AstroJohnPE
In Charlie's case, the analysis type was set to linear static stress. Contact only works in this analysis type when the gap/interference is 0. If the initial gaps are not critical to the design, I suggest that you remove them from the CAD model and start the process again. If the gap is critical to the design, then you must use an analysis type of "Nonlinear > MES". MES is the only analysis type that can handle surface contact between two surface with a gap.
For more information, see the page "Types of Contact" in the wikihelp. I will try to submit an update to the page to help make it clearer that contact requires a 0 gap in most situations.
Message 8 of 11
John,
This fixed my problem.  Many thanks!
Message 9 of 11
Junior_Brown
Hello Guys,
Could you please help? I am trying to analyse stresses in a spur gear during a complete rotation (i.e. 360 degrees). The pinion is rotating at a rate of 300 rpm and the main gear has a resisting torque of 225 in-lbs.  The pinion and gear teeth pass through each other without making surface to surface contact. Even though I am running the analysis within a Mechanical Event Simulation environment.
I have tried various ways to create surface contact pairs by assigning them manually as well as automatically (i.e. all surfaces on part 1 to all surfaces on part 2) but they still fail to make contact. I have even extended the analysis time but that did not work.
I have spent many hours trying to diagnose what the problem is and I am beginning to think that the simulation cannot be done with this software.  Is it possible? Can someone please help. I Cannot upload the ach file because of file size limitation on the forum. Please see attached  jpeg file showing the gear teeth passing through each other. Thanks.
Message 10 of 11
AstroJohnPE
in reply to: Junior_Brown
Hi Junior Brown,
It will be challenging to diagnose the model without having it. Did you read the thread "Create, Post, or Provide an Archive of your model" for tips on reducing the size of the archive?
Otherwise, here are some things to check:
  1. Read the log file from the Report environment. Just before the section that shows the time steps and iterations, the log file lists how many elements are in each part. Does the number of contact elements seem reasonable? (Be aware that the number reported is the initial number of elements. It can go up or down depending on the contact situation at each time step.)
  2. Do the reaction force results show any contact occurring between the teeth? If so, the contact stiffness can be increased to help prevent the teeth from passing through each other.
  3. What is causing the stress in the pinion? (I presume the blue color in your attached image indicates a non-zero stress. Please include the legend in future plots to help us interpret the image.)
  4. What version of the software are you using? (The annotation and legend colors imply a really old version, but perhaps you like that color scheme 🙂 The current version (2014) has some enhancements related to contact that would be helpful to you. (Such as grouping the  teeth surfaces so that you only need to define one contact pair, etc.)
  5. Until you get the bugs worked out, I suggest that you reduce the contact to just a few teeth.
  6. Why do you want to do a full rotation of the spur gear? Does something change so that the results after 360 degrees rotation are different than after 90 degrees? (2+ teeth on the pinion)
  7. Another option is to perform the analysis using 2D elements. Smaller model, faster run time. This can be done if the two gears are the same width (or you are willing to neglect the effects that occur when they are different widths.)
Message 11 of 11
Junior_Brown
Hi John,
Thanks for your reply. I am using version 18 (2005) of the software. I purchased it several years ago but did not get the chance to use it. I have now decided to use it as part of my design pipeline for product/machine design until I can afford to update it or purchase something better. One of the reasons why I bought it was for the?Multi-physics and MES capabilities as advertised by the previous developers. The reason for doing a full rotation is to demonstrate the power of the software to present and potential clients who use my services, - especially ?'non-technical' individuals. (I believe that engineering solutions should be made clear and simple so that they can be fully appreciated by all.)?
I want to do?a full analysis to determine the transient distribution in the pinion and the gear during a full rotation. ?Late last night (Wednesday, June 5), I discovered that I should have converted all the contact surfaces on the pinion to form a single solid Mesh?and then do the same for the gear.?( I believe that this is also one of your suggestions.) I also increased the Analysis Duration to 0.48 secs - the time taken to complete 2.4 revolutions at 300 rpm.?
After making those adjustments, the analysis would run for approximately 2 hrs and then crash. I am not sure what was causing it. I have tried to send the model 'ach' file to you but it was still too large. I have seen a written tutorial on the internet that is similar in some ways to what I want to achieve. Maybe you are familiar with it. Please?Go here
I will continue to try to solve this problem until I run out of options.
Thanks for your assistance,
Junior Brown
