Simulation Mechanical and Multiphysics
Valued Contributor
2 Kudos
Strange meshes
237 Views, 1 Replies
09-08-2013 10:13 AM
Hi
I have a assembly with a very strange meshing result.
See the picture below.
There are two identical tubes at the front of the assembly. The left tube is meshed OK. The right one is a mess.
I'm meshing the tubes using solid meshing of type Bricks and Wedges (Layered mesh of thin parts).
When I use the Midplane meshing, the right tubes almost disappears. See picture below
The tubes are identical (extruded from one sketch in Inventor). Any idea what could be wrong??
Valued Contributor
2 Kudos
Re: Strange meshes
09-12-2013 04:20 AM in reply to: mechamania
Found the problem.
Somebody told me the problem could be that I extrude both tunes into one part.
When I make two separate parts for the two tubes, all is ok.
