i am trying to simulate heat transfer of a chip on a PCB within a steady fluid. but i would like to get the variation of temperature with repect of time. i have the chip enclosed in the box (air part included) and the chip, the box, the air part and the board are enclosed in a bigger enclosure with another air part included also.
i tryied the transient steady coupled fluid flow-heat transfer when it is time to run the simulation, i get a message about " MPICH2 IS NOT INSTALLED OR NOT RUNNING PROPERLY"
what does the error means.
First of all, I think you are in the wrong forum. Two of Autodesk Simulation products have CFD capabilities, they are Autodesk Simulation Multiphysics and Autodesk Simulation CFD. Based on your description, I believe that you are using the former. You will get more relevant responses from the other Multiphysics forum:
http://forums.autodesk.com/t5/Autodesk-Simulation-Mechanical/bd-p/396.
Anyway, what you want (the variation of temperature with respect to time) is a transient coupled fluid flow and thermal analysis. For that, you will need to install the message passing interface (MPICH) that transfers data in between the fluid flow and temperature solver at each time step. That is how I understand it, for more information on the MPICH, look here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17176796&linkID=13806469
Regards
Ilyas
