Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
sguffy
352 Views, 1 Reply
starting a new block
I am a student and starting an autocad program and i have some questions about starting a block for my designs ( I am using the MACPRO version 2011). I made my block first and made my layers, or is not done the correct way? Now at the bottom for my texting I am stuck. I did go t my command line and typed in text followed that commands, but i cannot go further, what am i doing wrong? This seems to be the wrong way. Also when I doit that way my layer stays at the text, is that ok? Also wanted to add when this is completed how do i use that block and put around each one of my drafts?
1 REPLY 1
PipePakPat
in reply to: sguffy
I think this post would get more appropriate responses from within the Autodesk AutoCAD forum.  This forum is for simulation or finite element analysis.
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
