I am a student and starting an autocad program and i have some questions about starting a block for my designs ( I am using the MACPRO version 2011). I made my block first and made my layers, or is not done the correct way? Now at the bottom for my texting I am stuck. I did go t my command line and typed in text followed that commands, but i cannot go further, what am i doing wrong? This seems to be the wrong way. Also when I doit that way my layer stays at the text, is that ok? Also wanted to add when this is completed how do i use that block and put around each one of my drafts?
I think this post would get more appropriate responses from within the Autodesk AutoCAD forum. This forum is for simulation or finite element analysis.
