Hello fellow MS users,
I've been testing & learning MS 2014 for a couple of weeks now on a small inventor file. It worked OK for a couple of times then it started to fail part way through the simulation with the following error on the log file:
Error occurred with module: C:\Program Files\Autodesk\Simulation 2014\srunx.exe
I have tried all sorts of things to get it to work again but alas have failed. Can someone please advise me how to fix it.
I have attached the log file below.
Also, can someone explain why there is extra property inserts for a basic orthotropic material as opposed to a temperature dependent orthotropic material. The basic ortho material has for example, major and minor Poissons ratios, where as the TDO material does not have this option, only 12,13,23 axis. There are also other property inputs that are only available on the basic material. Surely a orthotropic material has the same types of properties, whether or not we want to run a temperature related simulation.
Any advice would be greatly appreciated,
Cam
I am encountering this same problem. What is the error? and what is the resolution?
Can you share your model? This can help us investigate the code.
-Shoubing
