Hi
I would like to make a 2D mes analysis
The thing is that when i import a dwg or dxf file in algor, all the domains are grouped in one part
and so impossible to automesh
this happens even if i asked algor to import seperate blocks as parts..
Thanks for your help
If Pro/E does not have a property that equates to a layer in the DXF file, then you need to change the part numbers of the lines within Simulation. (In other words, it is the AutoCAD layer number that automatically creates different parts when imported, but you knew that already from the documentation. 😉
The trickiest part about selecting the lines in Simulation is that there are many overlapping lines where the parts touch. (At least, I assume the parts are touching, otherwise it would be trivial to select them and change the part number.) What you could do is create N dxf files. Each dxf file has as many parts as possible that do not touch each other. This will make it easier to select the lines and change them. When you are done with one DXF file, merge the file and proceed with breaking it into parts.
