Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Sketch from Imported Wireframe
2 REPLIES 2
stevenaking
408 Views, 2 Replies
I am builring an axisymmetric model. I have an imported wireframe from CAD (iges). All of the curves are construction objects, and are in the YZ plane.
How can I make these existing curves into a sketch for 2-D meshing?
2 REPLIES 2
AstroJohnPE
in reply to: stevenaking
Hi Stevenaking,
When you are selecting the file to open, there is an "Option" button or something on the File> Open dialog. Click that, and the dialog that appears gives options to import the drawing to a plane or as 3D objects. Hopefully, that will be the difference.
Otherwise, you may be able to use the instructions in the paragraph "Convert from 3D objects to a sketch" on the page "Drawing Planes" in the help documentation.
stevenaking
in reply to: AstroJohnPE
This works. Thanks.
