I have a static linear analysis with a load of Fx=-9000N, Fy=6000N and Fz=5500N. The element is a plate element with a mesh generated by mid-plane automatic mesh generation from a solid body. What I observe is that the software is not calculating the simultaneous effect of Forces rather one at a time. Is there a button to consider simultaneous effect of forces. Many thanks for the help.
Cheers!!!!
Hi tibor,
Can you provide some more details about your situation. For example,
A few tips about applying loads:
Thanks John...I've input the resultant force and the corresponding vector component and direction and got the results that I want. For a solid element there is no problem to input individual component load.....Cheers!!!!!!!!!!!
