I cannot get simulation to solve. It solved my first load case just fine. I copied my first load case and added a centrifical load. It stops solving after it outputs the available hard disk space. See attached log file. Any suggestions please?
MIchael
Engineer
Polar Tank Trailer
Solved by Andrew.Sartorelli. Go to Solution.
Hi Michael,
From the log it looks like you are getting a warning:
Warning: Rotation rate set but no load case multiplier set
You may need to set the load multiplier in Analysis Parameters for your angular velocity.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
That is not a problem. I tried adding multipliers of 1 on the load cases.
It looks like you are using Simulation Mechanical 2013.00, I'd recommend upgrading to Simulation Mechanical 2013.20 or if you have subscription 2015 R1. There were a few issues in the first service pack for 2013 that seem related to the issue that you are having:
