Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
SImulation won't solve after it outputs available hard disk space
3 REPLIES 3
mschroepfer
489 Views, 3 Replies
I cannot get simulation to solve.  It solved my first load case just fine.  I copied my first load case and added a centrifical load.  It stops solving after it outputs the available hard disk space.  See attached log file.  Any suggestions please?
MIchael
Engineer
Polar Tank Trailer
3 REPLIES 3
Hi Michael,
From the log it looks like you are getting a warning:
 Warning: Rotation rate set but no load case multiplier set
You may need to set the load multiplier in Analysis Parameters for your angular velocity.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Andrew Sartorelli - Autodesk GmbH
That is not a problem.  I tried adding multipliers of 1 on the load cases.
It looks like you are using Simulation Mechanical 2013.00, I'd recommend upgrading to Simulation Mechanical 2013.20 or if you have subscription 2015 R1. There were a few issues in the first service pack for 2013 that seem related to the issue that you are having:
  • The results are not correct when load cases are calculated beyond the first one.
  • Linear analysis with Centrifugal load does not run with certain mesh size.
