Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Simulation stopping for no reason without error
1 REPLY 1
alexmbis
308 Views, 1 Reply
I have a problem with simulating steady fluid flow. My model finished analysing correctly until I refined the mesh. Now it stops the simulation without any warning after finishing step 15 of 30. Any ideas on how to fix this?
1 REPLY 1
Joey.X
in reply to: alexmbis
Thanks for attaching the log file, it indicates that the simulation stoped at the iteration which was not converged.
Change pressuer equation solver from iterative solver(default) to BCSLIB_EXT usually will take care of this issue.
go to Setup/"Parameters" /Solution tab/click ">>" from the line of "formulation"/find Solver control from Segregated options, change default to "BCSLIB_EXT", and refer to the attached image for this change.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
