The latest release of Simulation Mechanical is 2016.01.00.1295 29-Jul-2015, which is a service pack for Simulation Mechanical 2016.
The development team has been hard at work on this update, and there are over 30 bugs fixed in this service pack!
Analysis
CAD Interoperability
General / User Interface
Help Document
Results Accuracy
Report Environment
Third-Party FEA Support
Solved by Andrew.Sartorelli. Go to Solution.
The attachment did not 'attach'. See below. Im not versed in all the what I will call unusual things that one needs to click on to make the install work. I think that the Autodesk products are too difficult to install and too customizable.
Thanks Andrew.
I am having a trouble after installing the HOTFIX......The MES is not stopping after finishing the simulation. I am doing a Static MES. I check all solver and i have the same trouble. Any idea of how to fix this
Andrew, I still have not been able to gain credentials here to access Subscription! I will drop this topic for now.
