For those customers on subscription we have launched our first product enhancement release for Autodesk Simulation Mechanical 2015. Those with active subscription can sign in to the Subscription Center, and then navigate to Downloads, then Product Enhancements. Download and install “Autodesk Simulation Mechanical 2015 Product Enhancement”.
Note: Uninstalling Simulation Mechanical 2015 and Service Pack 1 is required before installing Simulation Mechanical 2015 Product Enhancement release.
A few of the enhancements contained within this release are:
For a more detailed description of the enhancements in this release please view the video presentation by Sualp Ozel, Product Manager for Simulation Mechanical, or review the release notes on the Simulation Mechanical 2015 help page.
It Seems somthing is wrong with redirecting page.
"The core node you are trying to access was not found, it may have been deleted. Please refresh your original page and try the operation again."
looking forward to hear from you
thanks
The installation notes make it sound like this installation is an amendment to the initial install.
When I run the installer it is labeled "Autodesk Simulation Mechanical 2015" and there is no mention of a Product Enhancement Release.
It notifies me that Sim 2015 is already installed and I cannot go any further.
Am I supposed to uninstall my initial installation?
Hi Andrew,
Yes, the product enhancement release does require a full uninstall of Simulation Mechanical 2015. I'll break it out from the rest of the text in my initial post so it is a little bit more clear.
It is important too that you grab the installer for the product enhancement section of the Subscription Center and not the standard downloads section.
Andrew,
The Mechanical Simulation Job Manager should uninstall automatically when using the Simulation Mechanical uninstall utility.
Thanks Andrew.
Do you know if the RMB option "Select Subentities" has been disabled in this release?
I use it quite a bit, and it doesn't seem to be there anymore.
Dear Sir,
Please help, I just try to compare simulation linear static stress run with SimMech and Nastran, but the Result are difference. (see picture below).
part dimension 15 x 30 x 200 (mm)
load 1000 N
mesh size 5mm
really appreciate your answer. thank you.
BR,
Fathur
