I am running a simulation of a rubberish (elastomer) cap being placed on a plastic. The issue is the model fails to complete about 40% through. When I switch the bottle material to a rigid material (say steel), the simulation completes. I have tried refining the mesh but the model still stalls around 40%. The model info is below. I am guessing that there is a node somewhere that is reaching an infinite displacement that the system can't fix. Is this a know issue for the MES function when running two bodies that both deform?
Model:
- MES with nonlinear material
- Bottle:
- Isotropic element
- Cap:
- Hyperelatic (Mooney-Rivlin)
- 4mm forced displacement
- Global surface contact
Anything would help.
Robert.
Hi Robert,
One thing I would try is increasing the number of time-steps in the model. Especially, if you are using the default time-step of 20 with a hyperelastic material in MES. While the solver will automatically decrease the size of time-steps based on convergence criteria, it is often better to manually add in those time-steps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi Robert,
You can try the two changes: (1) check 'adaptive contact stiffness option" for the contact pair, or (2) select 'user-defined" contact stiffness and input a value of 100.
Shoubing
